Re: 20 mm mikuni carb tuning
Andrew /
So I was super busy and didn't have time to work on this till today. However, I am still having horrible luck.
The bike only starts when I engage the choke, and after revving high it quickly dies no matter where I put the tuning screws.
I replaced the petcock, removed my fuel filter, replaced the fuel lines, and got a new plug. I think the throttle is functioning properly. I readjusted it when I installed the carb. If I can here the slide hitting metal when I let the throttle go it has to be closing right?
As for compression, I have gone ever the bike a few time and everything seems to be tight. I have a hard time getting to a couple screws because of the large intake, but I don't think I could be losing enough compression out of these screws to make the ped not start at all.
Please help! I am entirely out of solutions for this.
  20 mm mikuni carb tuningTopic by: Andrew Andrew 01/24/10 02:56PM
  Re: 20 mm mikuni carb tuningRe: mattology - mattology - 01/24/10 03:15PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 01/24/10 03:24PM
  Re: 20 mm mikuni carb tuningRe: Dan Dan 01/24/10 04:31PM
  Re: 20 mm mikuni carb tuningRe: mattology - mattology - 01/24/10 07:21PM
  Re: 20 mm mikuni carb tuningRe: King Drunky JCams King Drunky JCams 01/24/10 09:08PM
  Re: 20 mm mikuni carb tuningRe: . (Nick) . (Nick) 01/26/10 07:35PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 02/06/10 10:09PM
  Re: 20 mm mikuni carb tuningRe: Weak-Ends Tj Weak-Ends Tj 02/06/10 10:30PM
  Re: 20 mm mikuni carb tuningRe: Not Tate Not Tate 02/06/10 10:52PM
  Re: 20 mm mikuni carb tuningRe: funk funk 02/06/10 10:55PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 02/07/10 01:47AM
  Re: 20 mm mikuni carb tuningRe: . (Nick) . (Nick) 02/07/10 10:49AM
  Re: 20 mm mikuni carb tuningRe: Weak-Ends Tj Weak-Ends Tj 02/07/10 11:08AM
  Re: 20 mm mikuni carb tuningRe: funk funk 02/07/10 12:34PM
  Re: 20 mm mikuni carb tuningRe: Chris R Chris R 02/07/10 01:27PM
  Re: 20 mm mikuni carb tuningRe: . (Nick) . (Nick) 02/07/10 01:27PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 02/07/10 09:16PM
  Re: 20 mm mikuni carb tuningRe: Nash . Nash . 02/07/10 11:48PM
  Re: 20 mm mikuni carb tuningRe: -Riprips- ** -Riprips- ** 02/08/10 12:36AM
  Re: 20 mm mikuni carb tuningRe: Name Removed Name Removed 02/08/10 02:37AM
  Re: 20 mm mikuni carb tuningRe: bryan bryan 02/09/10 04:34PM
  Re: 20 mm mikuni carb tuningRe: Rick Rick 02/09/10 04:47PM
  Re: 20 mm mikuni carb tuningRe: Name Removed Name Removed 02/09/10 09:42PM
  Re: 20 mm mikuni carb tuningRe: onell onell 02/10/10 04:14AM
  Re: 20 mm mikuni carb tuningRe: Jesse Jesse 09/25/10 06:24PM
  Re: 20 mm mikuni carb tuningRe: ggs ggs 09/25/10 08:15PM
  Re: 20 mm mikuni carb tuningRe: Dick Tortuga Dick Tortuga 09/25/10 08:41PM
  Re: 20 mm mikuni carb tuningRe: Krys D Krys D 03/11/11 10:23AM
  Re: 20 mm mikuni carb tuningRe: Chris R Chris R 03/11/11 09:01PM
  Re: 20 mm mikuni carb tuningRe: Jake P Jake P 03/11/11 09:54PM
  Re: 20 mm mikuni carb tuningRe: Krys D Krys D 03/13/11 10:23AM
Click here to login.
