Re: Can someone explain launch levers to me?
steve /
on a single variated ped like peugeot or motobecane, when the engine spins up the variator slides open to change the gear ratio for higher speeds. the variator is a pulley that changes diameter. to accomodate the change in diameter and therefore change in belt tension, the engine rocks back on a pivot. a launch lever is just a way to stomp on your engine to keep it from variating. this keeps you in a lower gear so you can take off from the line or help up hills.
  Can someone explain launch levers to me?Topic by: Vova Fett Vova Fett 01/22/10 03:54PM
  Re: Can someone explain launch levers to me?Re: Freebird Freebird 01/22/10 03:57PM
  Re: Can someone explain launch levers to me?Re: Jeremy osborn Jeremy osborn 01/22/10 04:32PM
  Re: Can someone explain launch levers to me?Re: Bret Hoffman Bret Hoffman 01/22/10 05:35PM
  Re: Can someone explain launch levers to me?Re: Vova Fett Vova Fett 01/22/10 05:48PM
  Re: Can someone explain launch levers to me?Re: steve steve 01/22/10 05:57PM
  Re: Can someone explain launch levers to me?Re: Patrick Patrick 01/22/10 06:04PM
  Re: Can someone explain launch levers to me?Re: Vova Fett Vova Fett 01/22/10 06:10PM
  Re: Can someone explain launch levers to me?Re: Jaykayoh Jaykayoh 01/22/10 06:13PM
  Re: Can someone explain launch levers to me?Re: Patrick Patrick 01/22/10 06:27PM
  Re: Can someone explain launch levers to me?Re: Jesse Stephenson Jesse Stephenson 01/22/10 08:02PM
  Re: Can someone explain launch levers to me?Re: zeke zeke 01/23/10 10:01AM
  Re: Can someone explain launch levers to me?Re: rgag rgag 01/23/10 10:43AM
  Re: Can someone explain launch levers to me?Re: Jesse Stephenson Jesse Stephenson 01/23/10 10:48AM
  Re: Can someone explain launch levers to me?Re: steve steve 01/23/10 11:33AM
  Re: Can someone explain launch levers to me?Re: Bret Hoffman Bret Hoffman 01/24/10 05:47AM
  Re: Can someone explain launch levers to me?Re: the worst terry the worst terry 01/24/10 07:12AM
  Re: Can someone explain launch levers to me?Re: the worst terry the worst terry 01/24/10 07:17AM
  Re: Can someone explain launch levers to me?Re: zeke zeke 01/24/10 10:59AM
Want to reply to this thread?
