Re: more moby pics
Organ Robbin' /
How does running an air filter out and around then back up the outside of the bike solve any problems. You should be able to fit a nice air cleaner in there without it hitting the frame. Not to mention using pvc, radiator hose and then mounting the filter that probably fits on the carb just fine seems like a little more work than needs to be done. I also hate when people put those crappy tanks on there, might as well build a new frame if the other one is fucked, happens to mobys all the time. Also this guy must have had like 1000 little pieces of plate cause he used them for every mounting bracket on that thing. I dont like it, but who cares, its not my bike either.
Click here to login.
