Re: rod length vs port timing
clay /
i will be riding to the dyno this afternoon.
went from 79.9cc to 63.5cc
.5mm carbon reed from fiber
178 to 180 on the exh, no idea what transfers were before
same pipe
4mm shorter rod with crowded bearing
perfectly balanced crank
i still havent touched the ignition timing, when does a magneto fire?
transfers are blended into the case
  rod length vs port timingTopic by: clay clay 01/20/10 05:11PM
  Re: rod length vs port timingRe: clay clay 01/20/10 05:20PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/20/10 05:38PM
  Re: rod length vs port timingRe: clay clay 01/20/10 06:10PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/20/10 06:37PM
  Re: rod length vs port timingRe: Graham Motzing Graham Motzing 01/20/10 10:22PM
  Re: rod length vs port timingRe: clay clay 01/21/10 01:01AM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 01:14AM
  Re: rod length vs port timingRe: clay clay 01/21/10 12:03PM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 01:13PM
  Re: rod length vs port timingRe: clay clay 01/21/10 03:27PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 03:38PM
  Re: rod length vs port timingRe: clay clay 01/21/10 04:19PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 05:21PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 05:26PM
  Re: rod length vs port timingRe: clay clay 01/21/10 06:10PM
  Re: rod length vs port timingRe: clay clay 01/21/10 07:52PM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 08:08PM
  Re: rod length vs port timingRe: clay clay 01/21/10 08:20PM
  Re: rod length vs port timingRe: clay clay 01/21/10 08:46PM
  Re: rod length vs port timingRe: clay clay 01/21/10 09:18PM
  Re: rod length vs port timingRe: clay clay 02/05/10 12:57AM
  Re: rod length vs port timingRe: mattology - mattology - 02/05/10 01:15AM
  Re: rod length vs port timingRe: mattology - mattology - 02/05/10 01:17AM
  Re: rod length vs port timingRe: clay clay 02/05/10 09:40AM
  Re: rod length vs port timingRe: macelius-san macelius-san 02/05/10 07:45PM
  Re: rod length vs port timingRe: clay clay 02/06/10 11:21AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:02AM
  Re: rod length vs port timingRe: mattology - mattology - 02/07/10 01:05AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:12AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:14AM
  Re: rod length vs port timingRe: mattology - mattology - 02/07/10 05:58AM
  Re: rod length vs port timingRe: clay clay 02/07/10 09:51AM
Click here to login.
