Re: rod length vs port timing
clay /
i had a sneaking suspicion that i had soldered and drilled too many jets on the crappy oval mikuni and bought a new flatty on ebay for 75 to my door. all i had to do, (other than mount it) was drop the needle all the way down. this motor has never run this smooth or made as much power.
matt,
those port timing numbers are right on. it's revving so much higher that i need to drop a tooth on the front sprocket before i get hurt.
i'm also calling out bigblockfiero,
gas ports are the shit! i had no noticable heat fade on my local test hill.
  rod length vs port timingTopic by: clay clay 01/20/10 05:11PM
  Re: rod length vs port timingRe: clay clay 01/20/10 05:20PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/20/10 05:38PM
  Re: rod length vs port timingRe: clay clay 01/20/10 06:10PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/20/10 06:37PM
  Re: rod length vs port timingRe: Graham Motzing Graham Motzing 01/20/10 10:22PM
  Re: rod length vs port timingRe: clay clay 01/21/10 01:01AM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 01:14AM
  Re: rod length vs port timingRe: clay clay 01/21/10 12:03PM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 01:13PM
  Re: rod length vs port timingRe: clay clay 01/21/10 03:27PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 03:38PM
  Re: rod length vs port timingRe: clay clay 01/21/10 04:19PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 05:21PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 05:26PM
  Re: rod length vs port timingRe: clay clay 01/21/10 06:10PM
  Re: rod length vs port timingRe: clay clay 01/21/10 07:52PM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 08:08PM
  Re: rod length vs port timingRe: clay clay 01/21/10 08:20PM
  Re: rod length vs port timingRe: clay clay 01/21/10 08:46PM
  Re: rod length vs port timingRe: clay clay 01/21/10 09:18PM
  Re: rod length vs port timingRe: clay clay 02/05/10 12:57AM
  Re: rod length vs port timingRe: mattology - mattology - 02/05/10 01:15AM
  Re: rod length vs port timingRe: mattology - mattology - 02/05/10 01:17AM
  Re: rod length vs port timingRe: clay clay 02/05/10 09:40AM
  Re: rod length vs port timingRe: macelius-san macelius-san 02/05/10 07:45PM
  Re: rod length vs port timingRe: clay clay 02/06/10 11:21AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:02AM
  Re: rod length vs port timingRe: mattology - mattology - 02/07/10 01:05AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:12AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:14AM
  Re: rod length vs port timingRe: mattology - mattology - 02/07/10 05:58AM
  Re: rod length vs port timingRe: clay clay 02/07/10 09:51AM
Click here to login.
