Re: rod length vs port timing
Flagrant - /
Would milling away the walls of the closed transfers achieve your goals. You would have long exh and transfer duration. When considring decking the cylinder remember you only paid around a 100 for that thing. Instead you could lathe the head so that the outer circumference of the combustion area is removed leaving a combustion chamber that is recessed or protrudes into the cyl.
  rod length vs port timingTopic by: clay clay 01/20/10 05:11PM
  Re: rod length vs port timingRe: clay clay 01/20/10 05:20PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/20/10 05:38PM
  Re: rod length vs port timingRe: clay clay 01/20/10 06:10PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/20/10 06:37PM
  Re: rod length vs port timingRe: Graham Motzing Graham Motzing 01/20/10 10:22PM
  Re: rod length vs port timingRe: clay clay 01/21/10 01:01AM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 01:14AM
  Re: rod length vs port timingRe: clay clay 01/21/10 12:03PM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 01:13PM
  Re: rod length vs port timingRe: clay clay 01/21/10 03:27PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 03:38PM
  Re: rod length vs port timingRe: clay clay 01/21/10 04:19PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 05:21PM
  Re: rod length vs port timingRe: Flagrant - Flagrant - 01/21/10 05:26PM
  Re: rod length vs port timingRe: clay clay 01/21/10 06:10PM
  Re: rod length vs port timingRe: clay clay 01/21/10 07:52PM
  Re: rod length vs port timingRe: mattology - mattology - 01/21/10 08:08PM
  Re: rod length vs port timingRe: clay clay 01/21/10 08:20PM
  Re: rod length vs port timingRe: clay clay 01/21/10 08:46PM
  Re: rod length vs port timingRe: clay clay 01/21/10 09:18PM
  Re: rod length vs port timingRe: clay clay 02/05/10 12:57AM
  Re: rod length vs port timingRe: mattology - mattology - 02/05/10 01:15AM
  Re: rod length vs port timingRe: mattology - mattology - 02/05/10 01:17AM
  Re: rod length vs port timingRe: clay clay 02/05/10 09:40AM
  Re: rod length vs port timingRe: macelius-san macelius-san 02/05/10 07:45PM
  Re: rod length vs port timingRe: clay clay 02/06/10 11:21AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:02AM
  Re: rod length vs port timingRe: mattology - mattology - 02/07/10 01:05AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:12AM
  Re: rod length vs port timingRe: clay clay 02/07/10 01:14AM
  Re: rod length vs port timingRe: mattology - mattology - 02/07/10 05:58AM
  Re: rod length vs port timingRe: clay clay 02/07/10 09:51AM
Click here to login.
