Re: Lots of e50 kit questions
rofman /
Ya don't need a new clutch just thick springs and tuned. A starter kit what is that? buy a dmp or kstar 70cc kit and head,Techno circuit pipe. air filter 15mm bing 84#jet you have to match. even a half ass bevel match so gas mixture will not be blocked. gear at least 18x45 which is the same as 16x40 I run 17x40 you want to keep this kit because if you seize bad you can damage the crank or case you can use the stock crank if the bushing is good. Man this set up hits 45+ on the flat unported. U can rematch a polini on your case pretty mutch but that is it
Click here to login.
