Re: porting on 70cc treats kit install
Flagrant - /
A 50cc high comp head on that cylinder will probably be too much compression. A stock 50cc head on the cylinder has to have it's squish band relieved a bit only to make for a pretty high CR. All of this prattle depends on how high the cylinder is on the case---think base gasket thickness. The intake port can be widened but put the piston in the cyl to make sure you don't make it wider than the piston skirt.
Click here to login.
