Re: benelli/guzzi pipes
Organ Robbin' /
Sprockets are only interchangable with others that have a keyway to fit. Its made funny. I dont think any actually easily bolt up. The rear are standard italian 4 bolt stuff, just change out the rear sprocket if ya want more speed. I had my stock Robin bobbin around 35. I've ridden Pullstarts bike and with the pipe his was a little faster. I'd estimate around 38 top speed. Replace the intake and carb, put a pipe on and do some porting, you pretty much have a 50cc polini kit. There isnt much difference in port or transfer design on the polini, over stock. I'd rather have the Malossi since its 50cc's. 3 shoe clutch and you got a puch killer.
Click here to login.
