Peak power prior to WOT, how to improve
With my current setup I feel like my Puch is making peak power before WOT, and opening up to WOT doesn't make me go any faster, really. It's not lean bogging or four-stroking, it just stays at the same crazy revs and doesn't speed up. Does this mean there is untapped power I can take advantage of through gearing or in other ways?
Re: Peak power prior to WOT, how to improve
Probably. Do a plug chop at wot to be sure if your jetting is correct.
sounds like you need a different main jet
Well if my jetting is correct, how would you suggest proceeding?
I wonder if this is a timing issue, too....
get a better pipe and rejet ..
