Re: Slight blockage of PHBG idle jet passage??
Zachary Evans, Destroyer of Worlds /
there shouldn't be anything blocking the passage in the idle jet, especially not anything you can simply remove.
Things aren't engineered that way...
I have had stupid random shit clog up jets though, depending on how clean your work environment was when you last opened the carb, and your fuel filter.. probably metal shaving.
Click here to login.
