Re: Slight blockage of PHBG idle jet passage??
Chris Rice /
Are you talking about the idle jet itself? What happens if you back the air mixture screw out 2 full turns? If you are giving it throttle and it's just bogging, it's probably lean... What is this air filter stuff? Why did you remove your air filter to get your idle jet properly tuned?
Click here to login.
