Re: Quick AV10 bottom end gasket question
Ian T /
if you put the whole bottom end in the oven, the case halves will warm up faster than the higher density bearings and you should be able to get them apart. That being said, I have twice just wet sanded the mating halves and run without the gasket.
Want to reply to this thread?
