Re: 103 piston hole good times!
Tommy Too Tall /
I tore the motor apart last night and was treated lovely collection of various shapes and sizes of aluminum in every conceivable nook and cranny, some even made it upstream past the reeds into the carb.
Before I took it apart i put the head back on and did some measurements. The squish band was just over 2mm and the points were opening at 18deg.
I have a mvt cdi I hadn't put on yet, think with the timing curve this might be easier to avoid? I will probably put it on when I get everything back together.
Also I'll either weld up that hole on the head or run a stock head next time around. A 2mm squish is pretty safe if i remember correctly right.
  103 piston hole good times!Topic by: Tommy Too Tall Tommy Too Tall 01/16/10 07:21PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 07:40PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 07:41PM
  Re: 103 piston hole good times!Re: same mike same mike 01/16/10 08:35PM
  Re: 103 piston hole good times!Re: rofman rofman 01/16/10 08:35PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 08:43PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 08:45PM
  Re: 103 piston hole good times!Re: rofman rofman 01/16/10 08:59PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 10:21PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 11:06PM
  Re: 103 piston hole good times!Re: naz naz 01/16/10 11:29PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 11:42PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 11:55PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 12:07AM
  Re: 103 piston hole good times!Re: naz naz 01/17/10 12:53AM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 01:23AM
  Re: 103 piston hole good times!Re: Jesse Stephenson Jesse Stephenson 01/17/10 01:40AM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 01:51AM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 03:23AM
  Re: 103 piston hole good times!Re: Ian T Ian T 01/17/10 05:07AM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 02:25PM
  Re: 103 piston hole good times!Re: mit mortso mit mortso 01/17/10 02:32PM
  Re: 103 piston hole good times!Re: naz naz 01/17/10 02:49PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 04:04PM
  Re: 103 piston hole good times!Re: no groms no blasters no groms no blasters 01/18/10 05:50PM
  Re: 103 piston hole good times!Re: naz. naz. 01/18/10 07:51PM
  Re: 103 piston hole good times!Re: same mike same mike 01/18/10 11:11PM
  Re: 103 piston hole good times!Re: same mike same mike 01/18/10 11:14PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/20/10 04:35PM
Want to reply to this thread?
