Re: 103 piston hole good times!
Flagrant - /
OK howabout this; because the head has that void area it then warps when it gets hot. Mine doesn't do that though. It is stock. If you went water cooled you prob wouldn't be having these issues.
  103 piston hole good times!Topic by: Tommy Too Tall Tommy Too Tall 01/16/10 07:21PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 07:40PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 07:41PM
  Re: 103 piston hole good times!Re: same mike same mike 01/16/10 08:35PM
  Re: 103 piston hole good times!Re: rofman rofman 01/16/10 08:35PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 08:43PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 08:45PM
  Re: 103 piston hole good times!Re: rofman rofman 01/16/10 08:59PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 10:21PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 11:06PM
  Re: 103 piston hole good times!Re: naz naz 01/16/10 11:29PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 11:42PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 11:55PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 12:07AM
  Re: 103 piston hole good times!Re: naz naz 01/17/10 12:53AM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 01:23AM
  Re: 103 piston hole good times!Re: Jesse Stephenson Jesse Stephenson 01/17/10 01:40AM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 01:51AM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 03:23AM
  Re: 103 piston hole good times!Re: Ian T Ian T 01/17/10 05:07AM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 02:25PM
  Re: 103 piston hole good times!Re: mit mortso mit mortso 01/17/10 02:32PM
  Re: 103 piston hole good times!Re: naz naz 01/17/10 02:49PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 04:04PM
  Re: 103 piston hole good times!Re: no groms no blasters no groms no blasters 01/18/10 05:50PM
  Re: 103 piston hole good times!Re: naz. naz. 01/18/10 07:51PM
  Re: 103 piston hole good times!Re: same mike same mike 01/18/10 11:11PM
  Re: 103 piston hole good times!Re: same mike same mike 01/18/10 11:14PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/20/10 04:35PM
Click here to login.
