Re: 103 piston hole good times!
Tommy Too Tall /
The hole looks similar but I'm pretty sure the first one was a head leak, I was running without a head gasket in Portland and it looked like it was leaking from the head and decomp. The first piston hole is part of the reason I plugged the hole in the cylinder along with a lot of other preventive measures.
  103 piston hole good times!Topic by: Tommy Too Tall Tommy Too Tall 01/16/10 07:21PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 07:40PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 07:41PM
  Re: 103 piston hole good times!Re: same mike same mike 01/16/10 08:35PM
  Re: 103 piston hole good times!Re: rofman rofman 01/16/10 08:35PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 08:43PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 08:45PM
  Re: 103 piston hole good times!Re: rofman rofman 01/16/10 08:59PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 10:21PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 11:06PM
  Re: 103 piston hole good times!Re: naz naz 01/16/10 11:29PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/16/10 11:42PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/16/10 11:55PM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 12:07AM
  Re: 103 piston hole good times!Re: naz naz 01/17/10 12:53AM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 01:23AM
  Re: 103 piston hole good times!Re: Jesse Stephenson Jesse Stephenson 01/17/10 01:40AM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 01:51AM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 03:23AM
  Re: 103 piston hole good times!Re: Ian T Ian T 01/17/10 05:07AM
  Re: 103 piston hole good times!Re: Flagrant - Flagrant - 01/17/10 02:25PM
  Re: 103 piston hole good times!Re: mit mortso mit mortso 01/17/10 02:32PM
  Re: 103 piston hole good times!Re: naz naz 01/17/10 02:49PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/17/10 04:04PM
  Re: 103 piston hole good times!Re: no groms no blasters no groms no blasters 01/18/10 05:50PM
  Re: 103 piston hole good times!Re: naz. naz. 01/18/10 07:51PM
  Re: 103 piston hole good times!Re: same mike same mike 01/18/10 11:11PM
  Re: 103 piston hole good times!Re: same mike same mike 01/18/10 11:14PM
  Re: 103 piston hole good times!Re: Tommy Too Tall Tommy Too Tall 01/20/10 04:35PM
Click here to login.
