Re: Puch and Proma GP mount not perfect, suggestio
Chris Rice /
Get a strip of metal. Two holes spaced out to fit your gap. If the pipe isn't in line with the mount on the frame, get a spacer and cut it to fit. Then a bolt through with a nylock nut and washer on either side. You should be good to go...
Click here to login.
