Re: bad ass moby clutch tuning
Jesse Stephenson /
It's not a substitute for a clutch pulley, you will not achieve the same stall rpm that you can with most other clutches.
And the pads sit on a flat spring, so as the rpms go up the weight of the pad bends the arms out and engages the outer clutch bell. If you remove weight from the end then it wil engage at a later speed because there is less force pushing it outward. The problem is that's where the pad is located so the move you cut of the less pad you have, so you can only remove so much before there is no clutch. The other way around this is to add another pin close to the pad so you can keep pad but reduce the moment arm. Which is also a pain in the ass because the other side of the bell is another clutch surface for the starter clutch. You can try to weld t down but it ends up detempering the spring a bit. The distance from the pad and the outer bell is really small so it's hard to get it to not move that much. Even if you take the starter clutches out, cut almost all the pad of the arm, move the pivot point inward, and all that, it still will engage earlier than a puch 3 shoe with the springs run in.
  bad ass moby clutch tuningTopic by: johno roberts johno roberts 01/15/10 05:34AM
  Re: bad ass moby clutch tuningRe: Jesse Stephenson Jesse Stephenson 01/15/10 08:27AM
  Re: bad ass moby clutch tuningRe: CtpEDsHED . CtpEDsHED . 01/15/10 10:32AM
  Re: bad ass moby clutch tuningRe: Erik Elhammer Erik Elhammer 01/15/10 10:34AM
  Re: bad ass moby clutch tuningRe: same mike same mike 01/15/10 11:09AM
  Re: bad ass moby clutch tuningRe: tweeder tweeder 01/15/10 11:15AM
  Re: bad ass moby clutch tuningRe: Emperor Swagustus Emperor Swagustus 01/15/10 11:40AM
  Re: bad ass moby clutch tuningRe: Andy Andy 01/15/10 01:53PM
  Re: bad ass moby clutch tuningRe: Emperor Swagustus Emperor Swagustus 01/15/10 02:09PM
  Re: bad ass moby clutch tuningRe: Andy Andy 01/15/10 02:15PM
  Re: bad ass moby clutch tuningRe: johno roberts johno roberts 01/15/10 04:00PM
  Re: bad ass moby clutch tuningRe: Jesse Stephenson Jesse Stephenson 01/15/10 04:04PM
  Re: bad ass moby clutch tuningRe: Emperor Swagustus Emperor Swagustus 04/15/10 12:36PM
  Re: bad ass moby clutch tuningRe: Jesse Stephenson Jesse Stephenson 04/15/10 04:49PM
  Re: bad ass moby clutch tuningRe: Emperor Swagustus Emperor Swagustus 01/15/10 06:04PM
  Re: bad ass moby clutch tuningRe: .Allen Schlung .Allen Schlung 01/15/10 07:41PM
  Re: bad ass moby clutch tuningRe: Jesse Stephenson Jesse Stephenson 01/15/10 08:16PM
  Re: bad ass moby clutch tuningRe: Emperor Swagustus Emperor Swagustus 01/15/10 09:05PM
  Re: bad ass moby clutch tuningRe: steve steve 01/15/10 09:20PM
  Re: bad ass moby clutch tuningRe: Jaym Jaym 01/15/10 09:35PM
  Re: bad ass moby clutch tuningRe: Ponyboy MP Ponyboy MP 01/16/10 02:40AM
  Re: bad ass moby clutch tuningRe: Jesse Stephenson Jesse Stephenson 01/16/10 11:18AM
Want to reply to this thread?
