Re: Za50 clutches
keesmaxi /
There are 3 types of 2nd gear clutches.
The open type (you can see the spring) and the closed types.
Also the 2nd clutch come with a yellow and blue dot on it(stiffer spring) or with only one dot(yellow)
I got the same problem after flipping the clutch that there was a strange grinding sound onces a while.
Checked it, and it was the play on the ax-sprocket.
I made a shimring for it and it was gone.
Use a normal 1st gear clutch and a flipped 2 dotted 2nd gear clutch.
Use thick motoroil, 20-40 sprockets and with a fast 50cc is runs fine.
A 70cc is running better by the way..more torque..
  Za50 clutchesTopic by: Jake Harvey Jake Harvey 01/14/10 10:29PM
  Re: Za50 clutchesRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 01/15/10 02:01AM
  Re: Za50 clutchesRe: Deadped Ryan Deadped Ryan 01/15/10 12:08PM
  Re: Za50 clutchesRe: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 01/15/10 12:43PM
  Re: Za50 clutchesRe: Deadped Ryan Deadped Ryan 01/15/10 03:01PM
  Re: Za50 clutchesRe: Graham Motzing Graham Motzing 01/15/10 03:44PM
  Re: Za50 clutchesRe: keesmaxi keesmaxi 01/16/10 07:20AM
  Re: Za50 clutchesRe: Deadped Ryan Deadped Ryan 01/20/10 04:11PM
  Re: Za50 clutchesRe: blake blake 01/20/10 03:47PM
  Re: Za50 clutchesRe: sam Babcock sam Babcock 01/20/10 04:56PM
  Re: Za50 clutchesRe: Deadped Ryan Deadped Ryan 01/20/10 08:52PM
  Re: Za50 clutchesRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 01/20/10 09:34PM
  Re: Za50 clutchesRe: Deadped Ryan Deadped Ryan 01/20/10 10:36PM
  Re: Za50 clutchesRe: Deadped Ryan Deadped Ryan 01/20/10 10:41PM
  Re: Za50 clutchesRe: keesmaxi keesmaxi 03/13/10 12:57AM
  Re: Za50 clutchesRe: Mo Peds Mo Peds 03/13/10 01:13AM
  Re: Za50 clutchesRe: keesmaxi keesmaxi 03/16/10 09:18AM
  Re: Za50 clutchesRe: Todd rod Todd rod 03/23/10 12:59PM
  Re: Za50 clutchesRe: Deadped Ryan Deadped Ryan 03/14/10 08:22AM
  Re: Za50 clutchesRe: Jake P Jake P 03/15/10 12:29AM
  Re: Za50 clutchesRe: Jake P Jake P 03/23/10 05:34PM
  Re: Za50 clutchesRe: Todd rod Todd rod 03/23/10 05:42PM
  Re: Za50 clutchesRe: Jake P Jake P 03/23/10 06:08PM
  Re: Za50 clutchesRe: Todd rod Todd rod 03/23/10 06:37PM
  Re: Za50 clutchesRe: Todd rod Todd rod 03/23/10 06:38PM
  Re: Za50 clutchesRe: Todd rod Todd rod 03/23/10 06:40PM
  Re: Za50 clutchesRe: Jake P Jake P 03/23/10 06:59PM
Want to reply to this thread?
