Re: moby help
things that could be holding you back:
improper jetting
worn belt
stuck clutch/variator
brake drag
weird timing stuff
port issues
clogged exhaust?
also what stock intake are you using? the stock shorty is really small - like a 10 or 12mm. the bendy one is wider, but still wont be the right fit for a 16. so
big, giant air leak?
overly restrictive intake?
piston direction?
badly seating rings?
compression?
Click here to login.
