Re: java pipe examples
Graham Motzing /
it seems like java pipe is way out of its element with pipes the size for mopeds. It uses 'fudge factors' to calculate the pipe rather than actual thermodynamic modeling, so i dont think its worth much.
i've made 3 hydroformed expansion exhausts and after going through the work to make the first one, decided that skimping on the math is a waste of time. you're better off reading to get an understanding of what each change does, then modifying or reproducing an off-the-shelf pipe to make the changes you want to see.
  java pipe examplesTopic by: mike mike 01/14/10 01:29AM
  Re: java pipe examplesRe: Graham Motzing Graham Motzing 01/14/10 11:39AM
Click here to login.
