Timing Light
Adam Bandit /
I need to buy a timing light for Puch, Garelli, Motobecane, etc.
Does anyone know what the real difference is between these two?
Bright xenon bulb makes it easier to see timing marks.
-Accurate at all speeds
-Clamp-on inductive pickup, 4 ft. leads
-Trigger activated
-Automatic reverse polarity and overload protection
-Durable construction
Set timing advance without a degree scale on your engine. Simply set the advance on the timing light and align the timing mark to the TDC indicator on your engine.
-Easy-to-read 60 dial
-Neon indicator light insures proper hookup
-Bright xenon bulb
-Rubber nose protects the unit from damage
-Detachable leads
-Inductive pick-up
-Trigger-activated light
-High Impact ABS housing
  Timing LightTopic by: Adam Bandit Adam Bandit 01/13/10 12:46PM
  Re: Timing LightRe: Gabby Gabby 01/13/10 01:12PM
  Re: Timing LightRe: Adam Bandit Adam Bandit 01/13/10 03:13PM
Want to reply to this thread?
