Re: sachs prima g3 build help
Mike Bartell /
I did a steel motor mount and it stopped the movement. Just needed one, and that way I don't have to worry about re-drilling both frame mounts perfectly. Also cured the pipe shattering.
Found out that a lot of bicycle axles use m10x1 thread pitch, so thin nuts for double nutting the clutch shaft are out there and pretty available.
Just need more time to get mine back on the road, and see what effect lightening the clutch weight has. I dished the outermost plate on the clutch with the stock weight.
  sachs prima g3 build helpTopic by: nick nick 01/12/10 06:13PM
  Re: sachs prima g3 build helpRe: reynold reynold 01/12/10 06:35PM
  Re: sachs prima g3 build helpRe: nick nick 01/12/10 06:42PM
  Re: sachs prima g3 build helpRe: Tate Tate 01/12/10 10:04PM
  Re: sachs prima g3 build helpRe: Mike Bartell Mike Bartell 01/12/10 10:10PM
  Re: sachs prima g3 build helpRe: Mordecai Mordecai 01/13/10 01:47PM
  Re: sachs prima g3 build helpRe: Mike Bartell Mike Bartell 01/13/10 03:09PM
  Re: sachs prima g3 build helpRe: Mordecai Mordecai 01/13/10 03:16PM
  Re: sachs prima g3 build helpRe: nerdzilla in the north of he south nerdzilla in the north of he south 01/13/10 06:29PM
  Re: sachs prima g3 build helpRe: campeona del mundo campeona del mundo 01/13/10 11:00PM
  Re: sachs prima g3 build helpRe: Mordecai Mordecai 01/13/10 11:30PM
  Re: sachs prima g3 build helpRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 01/13/10 11:44PM
  Re: sachs prima g3 build helpRe: campeona del mundo campeona del mundo 01/14/10 12:12AM
  Re: sachs prima g3 build helpRe: nick nick 01/14/10 02:55AM
  Re: sachs prima g3 build helpRe: Graham Motzing Graham Motzing 01/14/10 12:21PM
  Re: sachs prima g3 build helpRe: Mike Bartell Mike Bartell 01/14/10 02:15PM
  Re: sachs prima g3 build helpRe: Organ Robbin' Organ Robbin' 01/14/10 02:23PM
  Re: sachs prima g3 build helpRe: nick nick 01/14/10 03:26PM
  Re: sachs prima g3 build helpRe: campeona del mundo campeona del mundo 01/14/10 06:03PM
  Re: sachs prima g3 build helpRe: nerdzilla in the north of he south nerdzilla in the north of he south 01/15/10 02:21PM
  Re: sachs prima g3 build helpRe: Graham Motzing Graham Motzing 01/15/10 03:38PM
  Re: sachs prima g3 build helpRe: nick nick 01/15/10 09:53PM
Want to reply to this thread?
