Re: Kitted Hobbit Overheating
- rwc - /
when my kitted hobbit was running out of gas, i found that the problem was float/inlet valve to the carb related. i did a little tab bending on the float and it solved my problem. if you decide to go this route, pay attention to whats going on with the two different ends of the "tab". try to isolate the bending to just the one end of the tab at a time. and after you get the whole fuel system clean(tank, carb, lines etc...) i would highly recommend the paper element fuel filters, like the ones from treatland.
Want to reply to this thread?
