Re: Kitted Hobbit Overheating
Mo Peds /
This sounds like you need to soak the carb also might have a dry seal. I would go buy some Berryman Carburetor kit cleaning system. Fluid the fuel system. Gas tank .... cock, line. The petcock comes apart and there is a screeen in there .. These honda pa50's camino hobbit's all had the same carb/idle problem if the carb is not super duper cleano.
Click here to login.
