Re: Kitted Hobbit Overheating
if your plug look good, sounds like you have another issue to me.. the carb clogging issue is more of a low speed circuit issue on these carbs and should still be able to drive the bike, it will just run like garbage at the bottom end. sounds like you have a coil going bad from my experience, alot of the time they start to go bad in this manner... i would go out and drive it till it dies and then take the cap off and see if it is getting spark
Click here to login.
