Re: Best E50 case gasket sealant
markryan /
yeah i highly advise against using rtv permatex because ive seen that stuff fail under constant exposure to gasoline. indian head is a shellac based sealer and is way thinner and solid of a sealer than most other products. indian head is also half the cost of rtv and can be found at auto zone. it works great in my experience.
it creates such a good seal you have to use a small amount of effort to pry your cases appart (nothing extreme- just a little added assurance its actually working)
right stuff (by permatex) is an elastomeric (sp?) rubber is the only gasket sealer ide use with constant expose to gasoline. makes a great stand alone intake and base gaskest sealer. believe it or not.
with gasoline nothing is guaranteed, but these two products are all id use as a sealer on a two stroke ever.
  Best E50 case gasket sealantTopic by: dave dave 01/10/10 07:19PM
  Re: Best E50 case gasket sealantRe: Responsible Jon Responsible Jon 01/10/10 07:30PM
  Re: Best E50 case gasket sealantRe: James G James G 01/10/10 07:32PM
  Re: Best E50 case gasket sealantRe: crazyjay vandal crazyjay vandal 01/10/10 07:55PM
  Re: Best E50 case gasket sealantRe: Andy Andy 01/10/10 08:22PM
  Re: Best E50 case gasket sealantRe: m m 01/10/10 08:39PM
  Re: Best E50 case gasket sealantRe: seank seank 01/10/10 10:10PM
  Re: Best E50 case gasket sealantRe: andrewhed andrewhed 01/10/10 11:30PM
  Re: Best E50 case gasket sealantRe: Flagrant - Flagrant - 01/10/10 11:57PM
  Re: Best E50 case gasket sealantRe: Nash . Nash . 01/11/10 12:04AM
  Re: Best E50 case gasket sealantRe: Conrad Conrad Conrad Conrad 01/11/10 12:49AM
  Re: Best E50 case gasket sealantRe: mattology - mattology - 01/11/10 01:19PM
  Re: Best E50 case gasket sealantRe: samsporter samsporter 01/11/10 04:44PM
  Re: Best E50 case gasket sealantRe: Mo Peds Mo Peds 01/11/10 05:16PM
  Re: Best E50 case gasket sealantRe: Mo Peds Mo Peds 01/11/10 05:17PM
  Re: Best E50 case gasket sealantRe: clay clay 01/12/10 01:03AM
  Re: Best E50 case gasket sealantRe: rafter rafter 01/12/10 01:12AM
  Re: Best E50 case gasket sealantRe: mit mortso mit mortso 01/13/10 06:21PM
  Re: Best E50 case gasket sealantRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 01/13/10 07:49PM
  Re: Best E50 case gasket sealantRe: Joshua r Joshua r 01/15/10 04:53PM
  Re: Best E50 case gasket sealantRe: markryan markryan 01/15/10 09:23PM
  Re: Best E50 case gasket sealantRe: mit mortso mit mortso 01/16/10 05:14AM
  Re: Best E50 case gasket sealantRe: Sadder Joey P Sadder Joey P 01/16/10 07:13AM
Want to reply to this thread?
