with the carb on the intake tight or loose it doesnt idle... but when you slide the carb back with it loose it idles... i jetted it before and came up brown like chocolate....would raising the needle to the top notch then rejetting it be ok? is that something to try? im thinking if i do that that then it would lean it out and i could just rejet. ?? ideas
Re: Can't keep idle and poor mpg
Want to reply to this thread?
