Re: 50 cc high compression head
Tate /
Yeah I would say go for it.
It will give you back some of the acceleration you lose with the pipe.
One bit of advice I will give you though is DO NOT TIGHTEN THE NUTS DOWN TOO TIGHT!
Also just go slow. When you you wrenching off/on the nuts make sure its all the turning motion and no side to side or up and down motion.
Treats has a good hi compression head. I think they call it the HI HI compression head.
http://www.treatland.tv/tomos-moped-50cc-high-compression-head-p/tomos-50cc-hi-head-targa-lx.htm
That one^
Also tomosi generally don't have head gaskets.
Its just 4 nuts off. Head off. New head on. 4 washers on. Four nuts back on.
Tighten down the nuts X wise. Like tighten upper left a little, then lower right, then lower left, then upper right and repeat. Its not about being really tight, its about being really even.
Don't quote me on this but I think tomos head nuts want like 7ft/lbs of torque.
As far as performance it will give you a little better acceleration all around. Sometimes noticeably faster on hills and such.
Click here to login.
