Re: Magnum X e50 Crank Different?
Saabsonettguy . /
I had the same problem, in my case it was the circlip behind the clutch which I had reused however it had become somewhat warped from removal. Its also possible that you don't have the right thickness shim for your crank/clutch bell combination.
Want to reply to this thread?
