getting speed out of a za50
Ƽɧ▲ɴƹ β /
If you don't want to flip your clutch just yet, all of this stuff is surprisingly easy to do, going from easiest to hardest/most tools required/cost:
- overfill your transmission fluid to about 12 ounces or so to make it shift later, also try using thicker oil to enhance this to your liking
- get a foam air filter like a K&N or UNI Pod (note, the UNI will require getting a cheap length of radiator hose and a few hose clamps at your local auto store)
- get a new exhaust (proma gp is a good one for stock cylinder)
- get a bigger intake manifold (the ZA50 requires TALLER ONES than the E50, the only stock ones were 12 and 14mm, if you have a 14mm, as I believe the 2HP do, just deal with it it's totally fine)
- get a bigger carb (bing 15 for example)
- pull your head, sand it down to increase compression or get a hi (or hi hi) compression head
- pull your cylinder and match your exterior intake and exhaust ports to your intake manifold and exhaust pipe header
Harder stuff that can get freaky and I haven't done yet:
- pull your cylinder, do a port map (search the site), and very mildly dremel/file your cylinder interior ports based on what people say in threads about puch port mapping (again, search the site)
- stuff your engine case full of silly putty (search) and grind your transfers down to match your cylinder better
- open your engine case and flip the clutch to make it shift later, if overfilling the transmission fluid didn't do what you wanted
When you order all these new parts, order a NICE BIG RANGE OF JETS because no one is going to be able to tell you what the hell you are going to need, get like everything from say, 64 to 84 because I'm placing a third order for a jet range and let me tell you it's annoying as all hell.
HTH
  getting speed out of a za50Topic by: Rowan Rowan 01/09/10 03:23PM
  Re: getting speed out of a za50Re: Sir Yancellot Sir Yancellot 01/09/10 03:32PM
  Re: getting speed out of a za50Re: derek derek 01/09/10 03:33PM
  Re: getting speed out of a za50Re: Deadped Ryan Deadped Ryan 01/09/10 05:06PM
  Re: getting speed out of a za50Re: Jake Harvey Jake Harvey 01/12/10 12:09AM
  getting speed out of a za50Re: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 01/12/10 12:19AM
  Re: getting speed out of a za50Re: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 01/12/10 01:37PM
  Re: getting speed out of a za50Re: Kit Carsick Kit Carsick 01/12/10 01:59PM
  Re: getting speed out of a za50Re: aph1979 aph1979 01/12/10 02:04PM
  Re: getting speed out of a za50Re: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 01/12/10 02:50PM
  Re: getting speed out of a za50Re: soulremedy2 soulremedy2 01/12/10 03:20PM
  Re: getting speed out of a za50Re: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 01/12/10 03:40PM
  Re: getting speed out of a za50Re: rofman rofman 01/12/10 06:27PM
  Re: getting speed out of a za50Re: [[ Linda ]] [[ Linda ]] 01/12/10 06:28PM
  Re: getting speed out of a za50Re: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 01/12/10 11:30PM
  Re: getting speed out of a za50Re: soulremedy soulremedy 01/12/10 10:34PM
  Re: getting speed out of a za50Re: Charles Cole (OFMC) Charles Cole (OFMC) 01/13/10 03:28AM
  Re: getting speed out of a za50Re: Deadped Ryan Deadped Ryan 01/13/10 05:33AM
  Re: getting speed out of a za50Re: derek derek 01/13/10 11:18AM
  Re: getting speed out of a za50Re: Ƽɧ▲ɴƹ β Ƽɧ▲ɴƹ β 01/13/10 12:05PM
  Re: getting speed out of a za50Re: blake blake 01/20/10 05:41PM
  Re: getting speed out of a za50Re: derek derek 01/20/10 09:17PM
  Re: getting speed out of a za50Re: Jake Harvey Jake Harvey 01/21/10 02:20PM
Want to reply to this thread?
