Re: SHOW ME YOUR DOPPLER SPRING!o
Unfortunately it's hard to recommend a specific weight I'm using a 40 lbs or 50 lbs at the moment can't remember, different variators and setups/belts require a bit of tuning weight wise. If you run a spring in conjunction with a damper, I suggest going with a lighter damper weight and use the spring for the tension and the damper, to well dampen. I've noticed the ER3 has tendency to like a spring and a damper and with a variotop I was able to just run the damper only, it's really strange. I just recently put a modified ER3 back on my bike and completed a fair amount of other work and will soon be switching from just a damper over to a spring and damper. Hopefully that helps with making decisions.
-naz
  SHOW ME YOUR DOPPLER SPRING!Topic by: ***Vanilla Thunder*** ***Vanilla Thunder*** 01/09/10 12:58PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Trina R Trina R 01/09/10 02:08PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Trina R Trina R 01/09/10 02:09PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Jesse -B Jesse -B 08/18/10 08:09AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 01/09/10 03:59PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: the worst terry the worst terry 01/09/10 04:07PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: naz naz 01/09/10 10:53PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Bacon Bacon 01/10/10 04:07AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: the worst terry the worst terry 01/10/10 06:08AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/10/10 06:24AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/10/10 06:26AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Jesse Stephenson Jesse Stephenson 01/10/10 12:29PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Fish tits Krauthamer Fish tits Krauthamer 01/10/10 12:59PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Nate Bandit Nate Bandit 01/10/10 01:03PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Bacon Bacon 01/10/10 02:33PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: ThunderB ThunderB 02/04/10 04:36PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Uphill Nate Uphill Nate 01/10/10 03:25PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/10/10 05:36PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: the worst terry the worst terry 01/10/10 07:00PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: naz naz 01/10/10 11:28PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: elliot elliot 01/11/10 12:13AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Bacon Bacon 01/11/10 12:50AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: naz naz 01/11/10 12:57AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/11/10 03:18AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Uphill Nate Uphill Nate 01/11/10 06:43AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Trina R Trina R 01/11/10 10:52AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: elliot elliot 01/11/10 03:15PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/11/10 04:03PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: elliot elliot 01/11/10 07:14PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/11/10 07:53PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: the worst terry the worst terry 01/11/10 07:30PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: fishstics fishstics 01/11/10 09:02PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/11/10 09:44PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: elliot elliot 01/12/10 02:16AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/12/10 03:21AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Un Lethocerus Un Lethocerus 01/12/10 11:05AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/12/10 01:37PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/12/10 07:27PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: elliot elliot 01/12/10 02:49PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Ian T Ian T 01/12/10 04:00PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: derbeez ryderz derbeez ryderz 01/12/10 05:21PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: the worst terry the worst terry 01/12/10 09:22PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Graham Motzing Graham Motzing 01/12/10 09:39PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: derbeez ryderz derbeez ryderz 01/12/10 10:55PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/13/10 12:07AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 09/30/10 04:47AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 10/01/10 12:48AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/01/10 03:59PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 10/01/10 10:56PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/02/10 11:00AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/02/10 11:13AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 10/02/10 12:24PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/05/10 03:36AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/05/10 03:41AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/06/10 08:57PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevin kevin 01/13/10 11:00AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Crackstar X Crackstar X 01/13/10 01:32PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/13/10 01:55PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 01/19/10 06:30PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Thunderbird Thunderbird 01/27/10 08:35PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 01/27/10 08:47PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: .Allen Schlung .Allen Schlung 01/13/10 02:26PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: .Allen Schlung .Allen Schlung 01/27/10 10:28PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Shalerrr rrr Shalerrr rrr 01/13/10 05:02PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Thunderbird Thunderbird 01/27/10 08:51PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 01/27/10 08:53PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Thunderbird Thunderbird 01/27/10 09:13PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/27/10 09:29PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: CtpEDsHED . CtpEDsHED . 01/27/10 09:48PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/27/10 10:15PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 02/05/10 04:21PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 02/16/10 10:03AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mikey q Mikey q 03/18/10 09:31PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: ThunderB ThunderB 02/16/10 04:44PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 02/16/10 05:09PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 03/19/10 02:42AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mikey q Mikey q 03/19/10 02:53AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: ThunderB ThunderB 03/31/10 02:25PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: bolig bolig 04/01/10 03:40AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Eric Sabatino Eric Sabatino 04/02/10 12:43PM
Click here to login.
