Re: SHOW ME YOUR DOPPLER SPRING!o
I was imagining something like a coil over suspension component for the motor damper. Turn a threaded body that slips over a damper and allows 2 interlocking collars that you can move to change the spring tension. I also started on a opening cheek rear pulley for a French bike as well, might as well and attack the issue for multiple angles. But I wanted to try and move in both directions since A: I just feel like there is more to be had out of the swinging motor setup then I've managed to get and want to push that all the way. I'm trying to figure out the correct belt to allow for full movement on a variotop and also modify and er3 enough to allow full movement from bottom to the top of the ramp plates. Think I've found the right parts just need to get them on order and do some more machining to the variators I have. B: I think front and rear moving cheeks allow for more gear range in the long run and hence most manufacturers moved that direction oddly enough it makes for a simpler setup but looses that original quality of the crazy contraption French bike.
-naz
  SHOW ME YOUR DOPPLER SPRING!Topic by: ***Vanilla Thunder*** ***Vanilla Thunder*** 01/09/10 12:58PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Trina R Trina R 01/09/10 02:08PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Trina R Trina R 01/09/10 02:09PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Jesse -B Jesse -B 08/18/10 08:09AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 01/09/10 03:59PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: the worst terry the worst terry 01/09/10 04:07PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: naz naz 01/09/10 10:53PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Bacon Bacon 01/10/10 04:07AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: the worst terry the worst terry 01/10/10 06:08AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/10/10 06:24AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/10/10 06:26AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Jesse Stephenson Jesse Stephenson 01/10/10 12:29PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Fish tits Krauthamer Fish tits Krauthamer 01/10/10 12:59PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Nate Bandit Nate Bandit 01/10/10 01:03PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Bacon Bacon 01/10/10 02:33PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: ThunderB ThunderB 02/04/10 04:36PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Uphill Nate Uphill Nate 01/10/10 03:25PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/10/10 05:36PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: the worst terry the worst terry 01/10/10 07:00PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: naz naz 01/10/10 11:28PM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: elliot elliot 01/11/10 12:13AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Bacon Bacon 01/11/10 12:50AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: naz naz 01/11/10 12:57AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Ian T Ian T 01/11/10 03:18AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Uphill Nate Uphill Nate 01/11/10 06:43AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: Trina R Trina R 01/11/10 10:52AM
  Re: SHOW ME YOUR DOPPLER SPRING!Re: elliot elliot 01/11/10 03:15PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/11/10 04:03PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: elliot elliot 01/11/10 07:14PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/11/10 07:53PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: the worst terry the worst terry 01/11/10 07:30PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: fishstics fishstics 01/11/10 09:02PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/11/10 09:44PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: elliot elliot 01/12/10 02:16AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/12/10 03:21AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Un Lethocerus Un Lethocerus 01/12/10 11:05AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/12/10 01:37PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/12/10 07:27PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: elliot elliot 01/12/10 02:49PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Ian T Ian T 01/12/10 04:00PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: derbeez ryderz derbeez ryderz 01/12/10 05:21PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: the worst terry the worst terry 01/12/10 09:22PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Graham Motzing Graham Motzing 01/12/10 09:39PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: derbeez ryderz derbeez ryderz 01/12/10 10:55PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/13/10 12:07AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 09/30/10 04:47AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 10/01/10 12:48AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/01/10 03:59PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 10/01/10 10:56PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/02/10 11:00AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/02/10 11:13AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 10/02/10 12:24PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/05/10 03:36AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/05/10 03:41AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mo Peds Mo Peds 10/06/10 08:57PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevin kevin 01/13/10 11:00AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Crackstar X Crackstar X 01/13/10 01:32PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/13/10 01:55PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 01/19/10 06:30PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Thunderbird Thunderbird 01/27/10 08:35PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 01/27/10 08:47PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: .Allen Schlung .Allen Schlung 01/13/10 02:26PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: .Allen Schlung .Allen Schlung 01/27/10 10:28PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Shalerrr rrr Shalerrr rrr 01/13/10 05:02PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Thunderbird Thunderbird 01/27/10 08:51PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 01/27/10 08:53PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Thunderbird Thunderbird 01/27/10 09:13PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/27/10 09:29PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: CtpEDsHED . CtpEDsHED . 01/27/10 09:48PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 01/27/10 10:15PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 02/05/10 04:21PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 02/16/10 10:03AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mikey q Mikey q 03/18/10 09:31PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: ThunderB ThunderB 02/16/10 04:44PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: kevinbvw kevinbvw 02/16/10 05:09PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: naz naz 03/19/10 02:42AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Mikey q Mikey q 03/19/10 02:53AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: ThunderB ThunderB 03/31/10 02:25PM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: bolig bolig 04/01/10 03:40AM
  Re: SHOW ME YOUR DOPPLER SPRING!oRe: Eric Sabatino Eric Sabatino 04/02/10 12:43PM
Click here to login.
