Re: qt50 tuning
Dedic761 /
dude you dont make any sense....we gave you a bunch of links with tons of information and you dont wanna take anything from a forum? this is a forum where your getting your information and all the same information! make sure your get a 501 cylinder because there is a 500 cylinder and a 501 and str8 from yamaha the 501 had mild porting, the exhaust was raised a mm and something on the intake i foreget, dont forget the clutch springs out of a pw50 to stall your takeoff. take out your oil injection and get an oil delete plug and run premix, convert your oil tank into a reserve tank, bore it out get yt60 piston from 86 i beleive, also go with the head because your piston will hit the stock head, or run 2 base gaskets to raise it a bit, buy a jemco or a dynoport exhaust, both are awesome, the vm 18 carb will do but youll have ot mod your throttle cable to fit it and have to make a shim, boyesen dual stage reeds work good also, the pw50 rear gears are a nice little add on top speed also.
  qt50 tuningTopic by: the artist formerly known as chin the artist formerly known as chin 01/08/10 11:47AM
  Re: qt50 tuningRe: Dedic761 Dedic761 01/08/10 01:10PM
  Re: qt50 tuningRe: harley_shopster harley_shopster 01/08/10 07:44PM
  Re: qt50 tuningRe: the artist formerly known as chin the artist formerly known as chin 01/08/10 08:21PM
  Re: qt50 tuningRe: Flagrant - Flagrant - 01/08/10 10:11PM
  Re: qt50 tuningRe: Dedic761 Dedic761 01/09/10 12:05AM
  Re: qt50 tuningRe: Dedic761 Dedic761 01/09/10 12:07AM
  Re: qt50 tuningRe: mauvescorpion mauvescorpion 01/09/10 01:44AM
  Re: qt50 tuningRe: Kansas John Kansas John 01/09/10 03:43AM
  Re: qt50 tuningRe: [[ Linda ]] [[ Linda ]] 01/09/10 04:09AM
  Re: qt50 tuningRe: the artist......... chin the artist......... chin 01/09/10 06:26AM
  Re: qt50 tuningRe: Dedic761 Dedic761 01/09/10 11:25PM
  Re: qt50 tuningRe: Flagrant - Flagrant - 01/09/10 11:33PM
  Re: qt50 tuningRe: the artist formerly known as chin the artist formerly known as chin 01/11/10 08:46AM
  Re: qt50 tuningRe: Dedic761 Dedic761 01/11/10 01:54PM
  Re: qt50 tuningRe: Troy Elizares Troy Elizares 01/11/10 05:52PM
  Re: qt50 tuningRe: the artist formerly known as chin the artist formerly known as chin 01/11/10 06:19PM
  Re: qt50 tuningRe: mauvescorpion mauvescorpion 01/11/10 11:06PM
  Re: qt50 tuningRe: Dedic761 Dedic761 01/11/10 11:51PM
  Re: qt50 tuningRe: "J" "J" 01/12/10 06:48AM
  Re: qt50 tuningRe: "J" "J" 01/12/10 06:50AM
  Re: qt50 tuningRe: the artist formerly known as chin the artist formerly known as chin 01/12/10 07:27AM
  Re: qt50 tuningRe: Dedic761 Dedic761 01/12/10 12:49PM
Click here to login.
