Re: The Tomos A55/A35 Intake Manifold Project...
R G /
Great photos, Lance. Keep going, many are watching with interest. SOme thoughts:
- 45-degree angles are better for flow speed. Think "laminar".
- Intake diameter should mimic your carb diameter for a few reasons: 1. optimizes the carb's atomization at lower throttle, 2. minimizes reflected pulses that slow down airflow, and 3. makes jetting easier at all throttle settings. Given that, it's probably OK to have your intake 1-2 mm larger than your carb with all the bends you are doing. Long intakes start creating a "tuned intake" effect, where a reflected pulse from the open end of the intake increases pressure as the piston ports close; as much as 10% if you get about 30" of intake, but only over a very narrow rpm range.
- Watch out for soldering, it could re-melt at engine temps. How about using JB-weld? Brazing is probably OK, but your cups are too deep with standard Home Depot copper pipe. I know I can't braze that good...
  The Tomos A55/A35 Intake Manifold Project...Topic by: Lance Campeau Lance Campeau 01/07/10 08:09PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Mo Peds Mo Peds 01/07/10 08:15PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Mo Peds Mo Peds 01/07/10 08:16PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Josh G Josh G 01/07/10 08:17PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/08/10 05:08AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/08/10 05:22AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: brandon. brandon. 01/08/10 05:26AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tate Tate 01/08/10 09:32AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/08/10 06:34PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Jake Mesa Jake Mesa 01/21/10 03:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tate Tate 01/08/10 06:56PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/08/10 06:59PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Durdan Durdan 01/08/10 07:16PM
  The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/08/10 11:50PM
  Re: The first photos...A55 high flow intake...Re: Mr. Duncan Mr. Duncan 01/09/10 12:29AM
  Re: The first photos...A55 high flow intake...Re: Lee Wittham Lee Wittham 01/12/10 01:58PM
  Re: The first photos...A55 high flow intake...Re: [[ Linda ]] [[ Linda ]] 01/09/10 12:47AM
  Re: The first photos...A55 high flow intake...Re: King Drunky JCams King Drunky JCams 01/09/10 01:16PM
  Re: The first photos...A55 high flow intake...Re: mattology - mattology - 01/09/10 02:11PM
  Re: The first photos...A55 high flow intake...Re: sterwiel sterwiel 01/09/10 02:53PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:23PM
  Re: The first photos...A55 high flow intake...Re: the worst terry the worst terry 01/09/10 07:28PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:50PM
  Re: The first photos...A55 high flow intake...Re: GARzan Justin GARzan Justin 01/09/10 07:51PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 08:02PM
  Re: The first photos...A55 high flow intake...Re: GARzan Justin GARzan Justin 01/09/10 07:53PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:53PM
  Re: The first photos...A55 high flow intake...Re: Tate Tate 01/09/10 08:36PM
  Re: The first photos...A55 high flow intake...Re: [[ Linda ]] [[ Linda ]] 01/09/10 08:45PM
  Re: The first photos...A55 high flow intake...Re: the worst terry the worst terry 01/09/10 08:53PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/09/10 10:17PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: zeke zeke 01/09/10 10:41PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/09/10 10:58PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/09/10 11:12PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/10/10 02:28AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: [[ Linda ]] [[ Linda ]] 01/10/10 02:48AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/10/10 03:13AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Bacon Bacon 01/10/10 03:57AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:09PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:16PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:20PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Trevor Yee Trevor Yee 01/10/10 06:51PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/11/10 01:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: cocoloco cocoloco 01/11/10 02:00PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/11/10 07:05PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chris Rice Chris Rice 01/12/10 03:28PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: GARzan Justin GARzan Justin 01/11/10 08:10PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/11/10 08:49PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: . (Nick) . (Nick) 01/12/10 12:41AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: [[ Linda ]] [[ Linda ]] 01/12/10 01:09AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: R G R G 01/12/10 03:12AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/12/10 03:37PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/13/10 01:23AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bunk Zilla bunk Zilla 04/04/10 11:40PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chris Rice Chris Rice 01/13/10 07:26PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chubbs Chubbs 01/12/10 07:53PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Eoban Eoban 01/13/10 05:41AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Josh J. Josh J. 01/13/10 03:36PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Jake Mesa Jake Mesa 01/13/10 03:50PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/13/10 09:03PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/13/10 06:12PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Cc250r Cc250r 01/13/10 07:58PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bryan bryan 01/13/10 10:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/16/10 02:46AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/17/10 01:04AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Charles Cole (OFMC) Charles Cole (OFMC) 01/17/10 02:47AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/17/10 04:12AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/23/10 08:35PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Joe Joe 06/17/10 04:51PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: nerdzilla in the north of he south nerdzilla in the north of he south 06/18/10 12:29PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tony Tony 06/18/10 02:00PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bryan bryan 06/18/10 05:15PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: LanceCampeau.com LanceCampeau.com 10/24/10 07:01PM
Click here to login.
