Re: The Tomos A55/A35 Intake Manifold Project...
Tate /
Well seems to me seeing as how a an A55 is piston port, a header is not a big deal to make. Any old exhaust pipe bent right would work I should think. Could even make one out of copper tubing and solder if you really wanted too.
The A35 is a whole other story. Its a much more common engine, I think there are only a handful of A55 riders on here and almost everyone has, had, or has a buddy that has an A35 on something.
The whole reed valve thing makes it a little more complicated.
Before I found a bunch of daelim intakes I was looking a fabing one. My criteria was an inner diameter of 19-21mm and an outter diameter of nor more than 24-26.
I was looking for some kind of pipe L union that could be welded onto a piece of 1/4 sheet steel with a 20mm hole drilled/cut in it.
Then I was going to hose mount a 19mm PHBG knock off to it,
I was going to test it out for a couple hundy miles and if it worked out and go from there.
I am still thinking it has to be done, because daelims can only go to about 17mm ID, and 19 is pretty much a minimum.
  The Tomos A55/A35 Intake Manifold Project...Topic by: Lance Campeau Lance Campeau 01/07/10 08:09PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Mo Peds Mo Peds 01/07/10 08:15PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Mo Peds Mo Peds 01/07/10 08:16PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Josh G Josh G 01/07/10 08:17PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/08/10 05:08AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/08/10 05:22AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: brandon. brandon. 01/08/10 05:26AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tate Tate 01/08/10 09:32AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/08/10 06:34PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Jake Mesa Jake Mesa 01/21/10 03:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tate Tate 01/08/10 06:56PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/08/10 06:59PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Durdan Durdan 01/08/10 07:16PM
  The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/08/10 11:50PM
  Re: The first photos...A55 high flow intake...Re: Mr. Duncan Mr. Duncan 01/09/10 12:29AM
  Re: The first photos...A55 high flow intake...Re: Lee Wittham Lee Wittham 01/12/10 01:58PM
  Re: The first photos...A55 high flow intake...Re: [[ Linda ]] [[ Linda ]] 01/09/10 12:47AM
  Re: The first photos...A55 high flow intake...Re: King Drunky JCams King Drunky JCams 01/09/10 01:16PM
  Re: The first photos...A55 high flow intake...Re: mattology - mattology - 01/09/10 02:11PM
  Re: The first photos...A55 high flow intake...Re: sterwiel sterwiel 01/09/10 02:53PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:23PM
  Re: The first photos...A55 high flow intake...Re: the worst terry the worst terry 01/09/10 07:28PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:50PM
  Re: The first photos...A55 high flow intake...Re: GARzan Justin GARzan Justin 01/09/10 07:51PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 08:02PM
  Re: The first photos...A55 high flow intake...Re: GARzan Justin GARzan Justin 01/09/10 07:53PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:53PM
  Re: The first photos...A55 high flow intake...Re: Tate Tate 01/09/10 08:36PM
  Re: The first photos...A55 high flow intake...Re: [[ Linda ]] [[ Linda ]] 01/09/10 08:45PM
  Re: The first photos...A55 high flow intake...Re: the worst terry the worst terry 01/09/10 08:53PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/09/10 10:17PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: zeke zeke 01/09/10 10:41PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/09/10 10:58PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/09/10 11:12PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/10/10 02:28AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: [[ Linda ]] [[ Linda ]] 01/10/10 02:48AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/10/10 03:13AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Bacon Bacon 01/10/10 03:57AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:09PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:16PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:20PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Trevor Yee Trevor Yee 01/10/10 06:51PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/11/10 01:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: cocoloco cocoloco 01/11/10 02:00PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/11/10 07:05PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chris Rice Chris Rice 01/12/10 03:28PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: GARzan Justin GARzan Justin 01/11/10 08:10PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/11/10 08:49PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: . (Nick) . (Nick) 01/12/10 12:41AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: [[ Linda ]] [[ Linda ]] 01/12/10 01:09AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: R G R G 01/12/10 03:12AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/12/10 03:37PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/13/10 01:23AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bunk Zilla bunk Zilla 04/04/10 11:40PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chris Rice Chris Rice 01/13/10 07:26PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chubbs Chubbs 01/12/10 07:53PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Eoban Eoban 01/13/10 05:41AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Josh J. Josh J. 01/13/10 03:36PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Jake Mesa Jake Mesa 01/13/10 03:50PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/13/10 09:03PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/13/10 06:12PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Cc250r Cc250r 01/13/10 07:58PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bryan bryan 01/13/10 10:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/16/10 02:46AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/17/10 01:04AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Charles Cole (OFMC) Charles Cole (OFMC) 01/17/10 02:47AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/17/10 04:12AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/23/10 08:35PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Joe Joe 06/17/10 04:51PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: nerdzilla in the north of he south nerdzilla in the north of he south 06/18/10 12:29PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tony Tony 06/18/10 02:00PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bryan bryan 06/18/10 05:15PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: LanceCampeau.com LanceCampeau.com 10/24/10 07:01PM
Click here to login.
