The Tomos A55/A35 Intake Manifold Project...
Lance Campeau /
Hello everyone:
As most Tomos A55/A35 owners already know... The market for larger intake manifolds for the Tomos engine is quite limited... In the case of the A55, the only way to get a high flow/high perfomance air intake manifold is make one yourself... So, being the enterprising person that I am... I am planing to custom build a series of larger intake manifolds for the A55 and A35 engines...
-stock 50cc
-Airsal 70cc
-Metra Kit 80cc
-Other?
The purpose of this posting is to gather some information as to what design would there be the greatest demand for for the meantime... I suspect that the A55 Airsal head would be most benifited by a larger intake manifold... so, I plan to start there...
What I need to know is what configuration most need or prefer... that is to say...
- what type of carb do you have?
This is the most important question... each carb has different specs and dimensions. The mounting system for the PHVA carb and the SHA carbs are totally different. I have never seen a 24mm flatslide so I have no idea how large the mounting flange is... does it use a plastic sleeve like the SHA carb? I need to catalog the different pipe sizes if I am to make any prototypes...
- do you have pedals or pegs
A peg bike could have the carb sticking out on a 90 degree angle but a pedal bike would need to have the carb mounted out of the way of the pedals... what would be prefered? forward facing (180 degree bend) or rear facing (two 90 bends with the opening facing toward the rear of the bike). Is it possible to mount the pedal arms on extenders?
- do you have electric start?
This limits the carb to right side mounting only...
- do you want your carb to fit side engine cover?
Are you looking for a descret & integrated look?
- do you want your carb sticking out?
Do you want you carb to stick out Steampunk Style?
The A35 intakes are much easier to fabricate then the A55 ones... Since I don't have access to all the different Tomos models to make measurements I will need Tomos owners on MopedArmy to help assist in this project.
What I need most is practial advice, measuments, size preferences etc...
do you want color? paint? powder coat? chrome? zinc plate?
What size is your intake port?
The list goes on and on.... Help me out guys.....
What do you guys need in an intake manifold pipe for your Tomos A35 or A55 engine?
Lance
  The Tomos A55/A35 Intake Manifold Project...Topic by: Lance Campeau Lance Campeau 01/07/10 08:09PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Mo Peds Mo Peds 01/07/10 08:15PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Mo Peds Mo Peds 01/07/10 08:16PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Josh G Josh G 01/07/10 08:17PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/08/10 05:08AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/08/10 05:22AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: brandon. brandon. 01/08/10 05:26AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tate Tate 01/08/10 09:32AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/08/10 06:34PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Jake Mesa Jake Mesa 01/21/10 03:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tate Tate 01/08/10 06:56PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/08/10 06:59PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Durdan Durdan 01/08/10 07:16PM
  The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/08/10 11:50PM
  Re: The first photos...A55 high flow intake...Re: Mr. Duncan Mr. Duncan 01/09/10 12:29AM
  Re: The first photos...A55 high flow intake...Re: Lee Wittham Lee Wittham 01/12/10 01:58PM
  Re: The first photos...A55 high flow intake...Re: [[ Linda ]] [[ Linda ]] 01/09/10 12:47AM
  Re: The first photos...A55 high flow intake...Re: King Drunky JCams King Drunky JCams 01/09/10 01:16PM
  Re: The first photos...A55 high flow intake...Re: mattology - mattology - 01/09/10 02:11PM
  Re: The first photos...A55 high flow intake...Re: sterwiel sterwiel 01/09/10 02:53PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:23PM
  Re: The first photos...A55 high flow intake...Re: the worst terry the worst terry 01/09/10 07:28PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:50PM
  Re: The first photos...A55 high flow intake...Re: GARzan Justin GARzan Justin 01/09/10 07:51PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 08:02PM
  Re: The first photos...A55 high flow intake...Re: GARzan Justin GARzan Justin 01/09/10 07:53PM
  Re: The first photos...A55 high flow intake...Re: Lance Campeau Lance Campeau 01/09/10 07:53PM
  Re: The first photos...A55 high flow intake...Re: Tate Tate 01/09/10 08:36PM
  Re: The first photos...A55 high flow intake...Re: [[ Linda ]] [[ Linda ]] 01/09/10 08:45PM
  Re: The first photos...A55 high flow intake...Re: the worst terry the worst terry 01/09/10 08:53PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/09/10 10:17PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: zeke zeke 01/09/10 10:41PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: the worst terry the worst terry 01/09/10 10:58PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/09/10 11:12PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/10/10 02:28AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: [[ Linda ]] [[ Linda ]] 01/10/10 02:48AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/10/10 03:13AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Bacon Bacon 01/10/10 03:57AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:09PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:16PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: sterwiel sterwiel 01/10/10 04:20PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Trevor Yee Trevor Yee 01/10/10 06:51PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/11/10 01:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: cocoloco cocoloco 01/11/10 02:00PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/11/10 07:05PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chris Rice Chris Rice 01/12/10 03:28PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: GARzan Justin GARzan Justin 01/11/10 08:10PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/11/10 08:49PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: . (Nick) . (Nick) 01/12/10 12:41AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: [[ Linda ]] [[ Linda ]] 01/12/10 01:09AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: R G R G 01/12/10 03:12AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: mattology - mattology - 01/12/10 03:37PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/13/10 01:23AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bunk Zilla bunk Zilla 04/04/10 11:40PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chris Rice Chris Rice 01/13/10 07:26PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Chubbs Chubbs 01/12/10 07:53PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Eoban Eoban 01/13/10 05:41AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Josh J. Josh J. 01/13/10 03:36PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Jake Mesa Jake Mesa 01/13/10 03:50PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Weak-Ends Tj Weak-Ends Tj 01/13/10 09:03PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/13/10 06:12PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Cc250r Cc250r 01/13/10 07:58PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bryan bryan 01/13/10 10:25PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/16/10 02:46AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/17/10 01:04AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Charles Cole (OFMC) Charles Cole (OFMC) 01/17/10 02:47AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/17/10 04:12AM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Lance Campeau Lance Campeau 01/23/10 08:35PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Joe Joe 06/17/10 04:51PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: nerdzilla in the north of he south nerdzilla in the north of he south 06/18/10 12:29PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: Tony Tony 06/18/10 02:00PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: bryan bryan 06/18/10 05:15PM
  Re: The Tomos A55/A35 Intake Manifold Project...Re: LanceCampeau.com LanceCampeau.com 10/24/10 07:01PM
Want to reply to this thread?
