Re: KSTAR port-map
GARzan Justin /
Hmm, okay. I only went up about 3mm on the exhaust, but I milled about 2mm off the top of the cylinder, then ported using that new height as zero; so my effective raise was 5mm on the exhaust, 2mm on the transfers. The cylinder is spaced from the bottom to match my new deck height, and I planed my head to maintain squish clearance. I shaped my exhaust port like that too, except not too prominent. My exhaust port was right at 30mm wide, from the window to the port, to match the Simonini header. For the intake, I went down about 1.5mm, didn't widen it too much. That's what keeps my power curve smooth; but I know I'm losing power because of it. Case induction will fix all that right up, though.
I went pretty radical with my piston on the mill, though. I connected both sets of holes, and lowered them about 2mm. This really helped the 6p with my loop scavenge, you should see the combustion patterns on my piston.
  KSTAR port-mapTopic by: - Summerai - Christine L - Summerai - Christine L 01/06/10 11:16PM
  Re: KSTAR port-mapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 01/06/10 11:25PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/06/10 11:31PM
  Re: KSTAR port-mapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 01/06/10 11:49PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/07/10 12:02AM
  Re: KSTAR port-mapRe: Nash . Nash . 01/07/10 12:16AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/07/10 12:25AM
  Re: KSTAR port-mapRe: clay clay 01/07/10 01:00AM
  Re: KSTAR port-mapRe: Erin L Erin L 01/07/10 05:02AM
  Re: KSTAR port-mapRe: mattology - mattology - 01/07/10 10:14AM
  Re: KSTAR port-mapRe: Jamesg Jamesg 01/07/10 10:24AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/07/10 11:45PM
  Re: KSTAR port-mapRe: Nash . Nash . 01/08/10 01:14AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/08/10 01:29AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/08/10 01:32AM
  Re: KSTAR port-mapRe: Flagrant - Flagrant - 01/08/10 02:07AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/08/10 02:32AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/08/10 02:53AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/08/10 02:56AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/08/10 03:30AM
  Re: KSTAR port-mapRe: Nash . Nash . 01/08/10 07:38PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/08/10 08:40PM
  Re: KSTAR port-mapRe: Nash . Nash . 01/08/10 11:33PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/09/10 02:15AM
  Re: KSTAR port-mapRe: Nash . Nash . 01/09/10 04:18AM
  Re: KSTAR port-mapRe: clay clay 01/09/10 11:08AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/09/10 04:27PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/09/10 04:28PM
  Re: KSTAR port-mapRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 01/09/10 05:07PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/10/10 12:21AM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/17/10 06:36PM
  Re: KSTAR port-mapRe: Nash . Nash . 01/10/10 08:55PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/17/10 10:29PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/17/10 11:24PM
  Re: KSTAR port-mapRe: Nash . Nash . 02/09/10 10:16AM
  Re: KSTAR port-mapRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 11:15AM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 01:06PM
  Re: KSTAR port-mapRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 01:36PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 02:02PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 02:03PM
  Re: KSTAR port-mapRe: [[ Linda ]] [[ Linda ]] 02/09/10 02:38PM
  Re: KSTAR port-mapRe: Kelin Kelin 02/09/10 02:54PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 02:56PM
  Re: KSTAR port-mapRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 03:01PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 03:05PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 03:07PM
  Re: KSTAR port-mapRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/09/10 04:28PM
Click here to login.
