Re: KSTAR port-map
Sadder Joey P /
i don't remember exactly what it was ported to. being as it's been almost a year. but i think it was like 3mm back on the intake, 2 wide on each side. 3 wide on the exhaust and raised 4? i think that cylinder i did some nerd power point tech on the exhaust. kinda like 0> but pointing up if you catch my drift. kinda helps on e50's since you don't have a clutch that throws you into a powerband or a variator to help you stay in a narrow one. remember. the more you raise your exhaust, the narrower your powerband gets. also make the four wndows 2 on the piston. polish your exhaust and transfers. and when you match your cases go all the way back. lots of power is lost when someone only matches the first inch into the case and leaves the transfer area by the crankcase stock. i feel like most builds i see are slowed down because of that actually.
  KSTAR port-mapTopic by: - Summerai - Christine L - Summerai - Christine L 01/06/10 11:16PM
  Re: KSTAR port-mapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 01/06/10 11:25PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/06/10 11:31PM
  Re: KSTAR port-mapRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 01/06/10 11:49PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/07/10 12:02AM
  Re: KSTAR port-mapRe: Nash . Nash . 01/07/10 12:16AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/07/10 12:25AM
  Re: KSTAR port-mapRe: clay clay 01/07/10 01:00AM
  Re: KSTAR port-mapRe: Erin L Erin L 01/07/10 05:02AM
  Re: KSTAR port-mapRe: mattology - mattology - 01/07/10 10:14AM
  Re: KSTAR port-mapRe: Jamesg Jamesg 01/07/10 10:24AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/07/10 11:45PM
  Re: KSTAR port-mapRe: Nash . Nash . 01/08/10 01:14AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/08/10 01:29AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/08/10 01:32AM
  Re: KSTAR port-mapRe: Flagrant - Flagrant - 01/08/10 02:07AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/08/10 02:32AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/08/10 02:53AM
  Re: KSTAR port-mapRe: Sadder Joey P Sadder Joey P 01/08/10 02:56AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/08/10 03:30AM
  Re: KSTAR port-mapRe: Nash . Nash . 01/08/10 07:38PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/08/10 08:40PM
  Re: KSTAR port-mapRe: Nash . Nash . 01/08/10 11:33PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/09/10 02:15AM
  Re: KSTAR port-mapRe: Nash . Nash . 01/09/10 04:18AM
  Re: KSTAR port-mapRe: clay clay 01/09/10 11:08AM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/09/10 04:27PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/09/10 04:28PM
  Re: KSTAR port-mapRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 01/09/10 05:07PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/10/10 12:21AM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/17/10 06:36PM
  Re: KSTAR port-mapRe: Nash . Nash . 01/10/10 08:55PM
  Re: KSTAR port-mapRe: GARzan Justin GARzan Justin 01/17/10 10:29PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 01/17/10 11:24PM
  Re: KSTAR port-mapRe: Nash . Nash . 02/09/10 10:16AM
  Re: KSTAR port-mapRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 11:15AM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 01:06PM
  Re: KSTAR port-mapRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 01:36PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 02:02PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 02:03PM
  Re: KSTAR port-mapRe: [[ Linda ]] [[ Linda ]] 02/09/10 02:38PM
  Re: KSTAR port-mapRe: Kelin Kelin 02/09/10 02:54PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 02:56PM
  Re: KSTAR port-mapRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 03:01PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 03:05PM
  Re: KSTAR port-mapRe: - Summerai - Christine L - Summerai - Christine L 02/09/10 03:07PM
  Re: KSTAR port-mapRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/09/10 04:28PM
Want to reply to this thread?
