Re: AV88 With an AV7 Topend?
Saabsonettguy . /
Its an av7 engine, so yes. The porting between the 50v's av7 and the av88's av7 is very similar. The main difference is that the cooling fins on the av88's motor are round, rather than squareish on the 50v. The av88 has different motor mounts than the 50v so you need to use the stock head.
Click here to login.
