Re: plug gap??
Smoking Bear /
the gap gives the spark somewhere controlled to happen.
without a spark, there's no ignition. without a controlled spark, the ignition would be quite erratic.
the gap can be set wider or smaller with a spark gapping tool if you want it to be accurate, or with a screwdriver if you're ok with approximate.
  plug gap??Topic by: Geoff Geoff 01/06/10 05:22PM
  Re: plug gap??Re: Smoking Bear Smoking Bear 01/06/10 05:27PM
  Re: plug gap??Re: Saabsonettguy . Saabsonettguy . 01/06/10 05:32PM
  Re: plug gap??Re: Jon Jon 01/13/10 02:21AM
Click here to login.
