Re: Vespa Exhust+air filter+upjett - question
Eran /
i will definitely get few jets to try, wouldn't hurt.
your setup does sounds close to mine, I only drilled one new hole but also re drilled the original holes bigger and removed all the plastic that was behind the metal screen, which BTW looks quit restrictive, thats why i'm thinking of getting a real hi flow filter.
since my variator is the rollers version and i took out two,i can try to take another one or two out and see what happens.
  Vespa Exhust+air filter+upjett - questionTopic by: Eran Eran 01/06/10 02:04PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/06/10 04:28PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 04:56PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Jamesg Jamesg 01/06/10 05:03PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:10PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 05:21PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/07/10 12:22AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:25AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:32AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:29PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 02:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 03:02PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 03:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 03:34PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 04:07PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:15PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:19PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:25PM
Click here to login.
