Re: Vespa Exhust+air filter+upjett - question
Chris Rice /
A pipe will make you loose low end for sure. That could be what you are experiencing... Like I said, you add to the top, you lose some low. You add some low, you lose some top...
I feel like you are still lean though... I'm sure jetting is a little different here than where you are so you may not need the jets that I specified... However it can't hurt to try a super rich jet just to make sure... Too lean will most definitely make you slow on take off.
  Vespa Exhust+air filter+upjett - questionTopic by: Eran Eran 01/06/10 02:04PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/06/10 04:28PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 04:56PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Jamesg Jamesg 01/06/10 05:03PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:10PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 05:21PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/07/10 12:22AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:25AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:32AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:29PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 02:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 03:02PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 03:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 03:34PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 04:07PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:15PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:19PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:25PM
Click here to login.
