Re: Vespa Exhust+air filter+upjett - question
Organ Robbin' /
Try running it with the side cover off and see if the variator is getting stuck or not coming out at the right time. I put a simo pipe after having a stock bike with a 13mm carb that ran and idled great..I went up 2 jet sizes with the big simo circuit pipe. Either way I didnt have to jump that high but then again someone else had installed the 13mm carb, but it was running great before that. This leads me to believe that something is up with your variator. Does it pull really hard off the line, or did it before you messed with it?
  Vespa Exhust+air filter+upjett - questionTopic by: Eran Eran 01/06/10 02:04PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/06/10 04:28PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 04:56PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Jamesg Jamesg 01/06/10 05:03PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:10PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 05:21PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/07/10 12:22AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:25AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:32AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:29PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 02:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 03:02PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 03:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 03:34PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 04:07PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:15PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:19PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:25PM
Click here to login.
