Re: Vespa Exhust+air filter+upjett - question
Chris Rice /
Totally different Simo pipe than I thought it was. Instead of covering up holes in your airbox, just buy some bigger jets. I would get 66, 68, 70 and 72 and start with a 72 main with your setup...
Either way you slice it though, adding a pipe always hurts your lowend... You gain some at the top, you always lose some at the bottom. It's that 2 stroke give and take...
A pipe will not make you better on hills if you can't get into the powerband of the pipe before or on the hill.
  Vespa Exhust+air filter+upjett - questionTopic by: Eran Eran 01/06/10 02:04PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/06/10 04:28PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 04:56PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Jamesg Jamesg 01/06/10 05:03PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:10PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/06/10 05:21PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/06/10 05:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Tate Tate 01/07/10 12:22AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:25AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:32AM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 02:29PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 02:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 03:02PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 03:58PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 03:34PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Chris Rice Chris Rice 01/07/10 04:07PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:15PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:19PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Eran Eran 01/07/10 04:23PM
  Re: Vespa Exhust+air filter+upjett - questionRe: Organ Robbin' Organ Robbin' 01/07/10 04:25PM
Click here to login.
