Re: Aluminum case welding procedure
Seank /
I would preheat for 10-15 min with mapgas it will help clean any impuritys out and will make welding much easier, where on the case are you welding because different places will pull draw or warp differently and the required amperage will be different depending on thickness.
Click here to login.
