Re: Max safe timing advance for kitted peugeot?
Have you tried 1.5 mm and tuned it proper to that timing? I would try that first so you have a safe starting point. Then, if you decide you would like to advance or retard your timing you have something to compare it to. I toasted a malossi piston within 5 miles, and I wasn't any further past 1.8mm. Not that it means that it will happen with your setup. As Naz said, all setups will be different. There are a ton of factors that will play into this.
Click here to login.
