Re: Explain reeds to me.
Silverfox Sullivan /
They are simply a check valve of sorts.
As the piston goes up it creates suction in the crankcase.
Atmospheric pressure pushes the reeds open and lets the fuel/air mixture into the crankcase.
When the piston comes down pressurizing the fuel/air mixture, the reeds snap shut not letting the pressurized fuel air mixture back out the inlet.
They are usually used when there is some radical inlet porting present.
Want to reply to this thread?
