Re: Who knows about pipe bending and modification?
Flagrant - /
Yep thats a harder pipe to bend because of those ridges. Also the sand method only works if the sand is packed in real tight with ends welded on. You could cut it further down and make a new cone section to weld on and then weld the header or bend the round metal header then weld it on. If you don't have a tig welder for that thin metal you can overlap the metal and braze it together
Click here to login.
