Re: how to case match without cracking the engine
Jon /
I've done the dean method with the hot glue, and it was cake. I stuffed newspaper in first to fill the big areas, then just coated the front and side edges with the hot glue. And if it's tricky to remove, just ram the hot tip around to break it up afterwards. No shavings in the crank at all.
  how to case match without cracking the engine caseTopic by: Ian Ian 01/02/10 03:09PM
  Re: how to case match without cracking the engineRe: GARzan Justin GARzan Justin 01/02/10 03:13PM
  Re: how to case match without cracking the engineRe: SABAT! andDestroy SABAT! andDestroy 01/02/10 03:38PM
  Re: how to case match without cracking the engineRe: Ian Ian 01/02/10 03:47PM
  Re: how to case match without cracking the engineRe: Sunset Paul Sunset Paul 01/02/10 03:55PM
  Re: how to case match without cracking the engineRe: mit mortso mit mortso 01/02/10 04:00PM
  Re: how to case match without cracking the engineRe: SABAT! andDestroy SABAT! andDestroy 01/02/10 04:03PM
  Re: how to case match without cracking the engineRe: rofman rofman 01/02/10 04:14PM
  Re: how to case match without cracking the engineRe: Flagrant - Flagrant - 01/02/10 04:14PM
  Re: how to case match without cracking the engineRe: Tom STL Tom STL 01/02/10 04:23PM
  Re: how to case match without cracking the engineRe: Josh G Josh G 01/02/10 04:39PM
  Re: how to case match without cracking the engineRe: Kansas John Kansas John 01/02/10 04:59PM
  Re: how to case match without cracking the engineRe: Ian Ian 01/02/10 05:10PM
  Re: how to case match without cracking the engineRe: joshua joshua 01/02/10 05:17PM
  Re: how to case match without cracking the engineRe: Tom STL Tom STL 01/02/10 05:18PM
  Re: how to case match without cracking the engineRe: the worst terry the worst terry 01/02/10 05:24PM
  Re: how to case match without cracking the engineRe: Patrick Lowery Patrick Lowery 01/02/10 05:34PM
  Re: how to case match without cracking the engineRe: CtpEDsHED . CtpEDsHED . 01/02/10 08:17PM
  Re: how to case match without cracking the engineRe: Gabe Bandit Gabe Bandit 01/02/10 08:45PM
  Re: how to case match without cracking the engineRe: peter peter 01/02/10 09:08PM
  Re: how to case match without cracking the engineRe: fishstics fishstics 01/02/10 09:29PM
  Re: how to case match without cracking the engineRe: jack jack 01/03/10 02:26AM
  Re: how to case match without cracking the engineRe: -Brian- The Ruffians STL -Brian- The Ruffians STL 01/06/10 04:29PM
  Re: how to case match without cracking the engineRe: Josh G Josh G 01/06/10 08:31PM
  Re: how to case match without cracking the engineRe: Jon Jon 01/13/10 02:17AM
  Re: how to case match without cracking the engineRe: Jaym Jaym 01/13/10 02:59AM
  Re: how to case match without cracking the engineRe: Organ Robbin' Organ Robbin' 01/13/10 10:53AM
  Re: how to case match without cracking the engineRe: - Summerai - Christine L - Summerai - Christine L 01/13/10 11:47AM
  Re: how to case match without cracking the engineRe: Mo Peds Mo Peds 01/13/10 12:51PM
  Re: how to case match without cracking the engineRe: MikeGeez MikeGeez 01/13/10 01:24PM
  Re: how to case match without cracking the engineRe: rock finally shredding pow rock finally shredding pow 01/13/10 01:33PM
  Re: how to case match without cracking the engineRe: - Summerai - Christine L - Summerai - Christine L 01/13/10 02:49PM
  Re: how to case match without cracking the engineRe: Ian Ian 01/13/10 03:36PM
  Re: how to case match without cracking the engineRe: mauvescorpion mauvescorpion 01/13/10 03:50PM
Click here to login.
